Marantz CD-63SE Special Edition Stereo CD Player (sold)
Made In Japan
Note : Previous Owner Just Change New CD Laser Lens and Tray Loading Gear for this Marantz CD63SE CD Player, Now working Flawlessly.
This is a legendary player - one of the all times best-sellers. Cheap but sounding like high end.
It has raw, dynamic, energetic, if maybe not most refined sound. Many companies used to tweak it and mod it, because it is such great base unit.
It has simple NPC SM5872 dac (Nippon Precision Circuits). Datasheet quotes: "CMOS LSI (Digital D/A Converters with Built-in Digital Filters
The DECO SM5872A/B D/A converters are high-speed converters for digital audio systems. They are fabricated in Molybdenum-gate CMOS. They incorporate a two-channel, 16-bit D/A converter and a digital eight-times oversampling filter, making them ideal for use in PCM and CD players and digital amplifiers. The Σ DECO SM5872A/B operate at 32, 44.1 and 48kHz sampling frequencies and incorporate deemphasis, attenuation and soft mute functions. " End of quotation...
Anyway, CD63 was one of the first Marantzes using a non-Philips DAC. Still a philips mechanism althouh it is a very very cheap and flimsy application of CDM12. The CD player has few op-amps, all elements are placed on one huge PCB, the output stage is minimalistic with tin-can- protected elements which may even be discrete. That would be the simplest CD player with discrete output - but - wait a minute - the op-amps are still in the path or so it seems.
The specifications:
Digital converter: SM5872BS, 1 bit linear/ch
CD Mechanism: Philips CDM-12.1
Frequency response: 5Hz to 20kHz
Dynamic range: >96dB
S/N Ratio: >104dB
Channel separation: 102dB / 1kHz
THD: > 0.0025% / 1kHz
Line output: 2V
Digital outputs: coaxial: .05Vp-p/75 ohms S/PDIF,
optical -19dBm optical TOS link
Power consumption: 13/12 watt
Dimensions: 420 x 86 x 300mm
weight: 5.6 kg
Made In Japan
The specifications:
S/N Ratio: >104dB
Line output: 2V
weight: 5.6 kg
- Number of posts : 2971
» Marantz CD-63SE Special Edition CD Player (Used) SOLD
» Marantz cd 63SE CD player(special edition) (SOLD)
» Marantz CD-63 Special Edition CD Player (Sold)
» Marantz CD-50 Special Edition CD Player (Used) SOLD
» Marantz CD-72mk2 SE (Special Edition) CD Player (Used) SOLD
