Bowers & Wilkins (sold)
Made In ENGLAND
Bowers & Wilkins B&W DM601 S1 Speakers
The Bowers & Wilkins DM601 Speaker is a bookshelf speaker system with a signal-to-noise ratio of 88 dB. This Bowers & Wilkins speaker has a double skinned baffle construction and uses extra internal bracing for reduced coloration and clearer sound. This Bowers & Wilkins bookshelf speaker has a frequency response ranging from 60 Hz to 22 kHz. This Bowers & Wilkins speaker has an impedance rating of 8 ohms, and a crossover point at 4 kHz. The Bowers & Wilkins DM601 Speaker uses a 6.5" woven Kevlar cone bass driver and a 1" Nautilus tube-loaded metal dome tweeter to ensure that both highs and lows are reproduced without any distortion.
Features:
Speaker Type: Main / Stereo
Mounting: Bookshelf
Construction: 2-Way vented-box system
Drive units: 1 x 25mm metal dome high-frequency | 1 x 165mm Kevlar cone bass / midrange
Specifications:
Power Handling: 25W -100W into 8 ohms
Frequency Response: 70Hz - 20kHz ± 3dB on reference axis
Impedance: 8 ohms (minimum 4.2 ohms)
Sensitivity: 88dB spl (2.83V 1m)
Dimensions (W x H x D): 204 x 356 x 244 mm
Weight: 6.1 kg
Last edited by HiFiLab on Fri Oct 23, 2020 9:42 pm; edited 1 time in total (Reason for editing : Sold)
- Number of posts : 2971
BUMP
UP
» Bowers&Wilkins 685(used)sold
» Bowers&Wilkins 683(used)sold
» Bowers and Wilkins PX - SOLD
» Bowers & Wilkins DM 603 S3 and DM 602.5 S3 (Used) - SOLD
» Bowers & Wilkins DM4 B&W UK (sold)
