Denon PMA-710AE High Current Amplifier ( SOLD )
Bigger brother to the Denon PMA-510, the main differences between the two models are greater power output, higher quality selected electronic components for better sound quality and more comprehensive features. Power output is up to 2 x 50W into 8 ohms and 2 x 85W into 4 ohms, backed up by a stiffer power supply with high reservoir capacitance giving better defined bass. Connectivity is in line with the PMA510 with 5 line, 1 phono inputs and 2 tape outputs. A pre-amplifier output is available on the Denon PMA-710 enabling you to route music to a second room, or drive a second power amp to bi-amp you main speakers.
Source direct button gives less internal noise for improved clarity of sound, loudness and tone controls allow you to adjust the sound to exactly suit your own musical tastes. Two sets of speaker can be connected with independent switching on/off of each pair. The ideal hifi amplifier for those on a budget but also requiring high sound output for larger rooms.
Power output: 50 watts per channel into 8Ω (stereo)
Total harmonic distortion: 0.07%
Input sensitivity: 2.5mV (MM), 105mV (line)
Signal to noise ratio: 86dB (MM), 107dB (line)
Dimensions: 434 x 121 x 307mm
Weight: 6.7kg
Year: 2009
*Condition 8/10*Like New
*Comes with Remote Control*
Price - RM750
Raj-0126657671
Weight: 6.7kg
Year: 2009
Price - RM750
Raj-0126657671
rasenthiran- Frequent Contributor
- Number of posts : 2533
Source(s): Parasound Zdac/Marantz Cd 63 KI/Sony X505ES/
Amplification: Exposure Super 10/Classe DR-6/Sony TA N90ES/Sansui AU 777 /AU-719/Yamaha RXV-863 Receiver
Speakers: NHT Classic/Monitor Audio Studio 2/Heybrook HB 1
» Denon PMA-520AE High Current Amplifier sold
» Denon PMA-2000AE Integrated Amplifier - Ultra High Current MOS
» Adcom GFA 545 II High Current Power Amplifier [used]-sold
» Parasound HCA-1200 II High Current Power Amplifier SOLD
» Rotel RA 1060 High Current Intergrated Amplifier(sold
