Isotek Mini Sub Power Conditioner (Used)
Isotek Mini Sub Power Conditioner (Used) Empty Isotek Mini Sub Power Conditioner (Used)
Post by raymond88 Sat Sep 03, 2011 11:20 am
Item: Isotek Mini Sub Power Conditioner
Condition: 8/10. In very good condition. Comes complete with power cord.
Price: RM1.8k
Contact: Raymond 012-3816611
Isotek Mini Sub Power Conditioner (Used) Isotek11
Isotek Mini Sub Power Conditioner (Used) Isotek12
Isotek Mini Sub Power Conditioner (Used) Isotek13
Isotek Mini Sub Power Conditioner (Used) Isotek14
Some info:
IsoTek Mini Sub Line Conditioner
Overview:
The Mini Sub has been universally accepted as the best component from component isolating mains power distributor at their price point. It was designed to be a very rewarding single box ‘plug-n-play’ solution for a complete audio or home theater system. The Mini Sub offers astounding value for money and gives a taste of what our truly high-end solutions offer.
At the rear of the unit you will note six high quality outlets, these are individually filtered to stop components ‘talking’ to each other or corrupting the clean supply provided by the unit. This is achieved by a series of delta filters on the outputs and a sophisticated filter circuit, which was inspired by work in cryogenics, and harnesses the technique used for the switching of cryogenic coils. Both products feature our new ‘Polaris-X’ technology that draws mains contaminants away from audio components plugged into the unit.
Outputs 1 & 2 have been given a higher power rating and should be used for high current devices, for example power amplifiers, integrated amplifiers, some ‘tube’ preamplifiers, projectors and plasma screens etc. The remaining four are suitable for all other equipment, for example CD players, turntables etc…
Mini Sub features enhanced protection through stabilizing the units voltage and giving it a very large absorption ability, this is extremely important in today’s society where dangerous power surges can damage sensitive audio equipment.
All fusing is external; this eliminates any need to enter the product. The unit is so safe that even if the mains are wired incorrectly in the rest of the house or environment that the product is used, the unit will correct the problem sonically.
All components are of the highest grade and are under stressed, this gives greater longevity. These are hand soldered onto a PCB with silver solder, the large PCB also features a ground plane upper surface acting as a very high grade common mode filter across the whole board, this allows the unit to act as a true faraday cage, and protecting itself from RFI and other components from the job it performs.
System integration:
We strongly recommend that a good quality mains cable is used and this cable is consistent throughout your system. Look for a cable with good conductors, for example oxygen free copper, this cable should also have a high degree of shielding from RFI.
Features:
• GII design featuring 'Polaris-X' technology
• Full component from component isolation
• Suitable for a complete system
• Plug in & play installation
• Power surge protection
• External fusing
• Dedicated ground post
• 6 high quality unswitched outlets
• 2007 Stereo Sound & Vision Category Winner
• 2004 Hi-Fi Choice Category Winner
• 2004 What Hi-Fi? Category Winner
• 2004 What Hi-Fi? 5 Star Winner
Website info:
http://www.gcaudio.com/cgi-bin/store/showProduct.cgi?id=531
Thank you.
Number of posts : 10573
Isotek Mini Sub Power Conditioner (Used) Empty Re: Isotek Mini Sub Power Conditioner (Used)
Post by raymond88 Mon Sep 12, 2011 11:50 am
