Jolida JD 200 tube CD player
$1388 brand new include delivery
Improved version of the JD100 with 4 tubes and direct DAC to tube +2 tubes to regulate the feed for a warmer sound. With Remote control
FEATURES:
6 vacuum tubes reference class cd player
Gain stage utilizing 2 x 12AX7 and 2 x 12AU7 vacuum tubes
Full vacuum tubes analogue stage without op amps
High voltage stabilization by 12AX7 and 6N6 for refined sound
Completely new pcb redesign and analogue stage
A new stage for filtering and impedance matching added
High end Germany MUNDORF MKP capacitors
Transparent window above tubes with blue led lights
Phillips laser mechanism with Burr Brown DAC chipset
2 high grade transformers (1 each to analog and digital sessions)
RCA unbalanced output x 2 pairs
Full function metallic remote control.
Detachable power cord (IEC)
TECHNICAL:
Frequency Response: +/- 0.5db, 20Hz to 20KHz
S/N Ratio: >102db
THD: <0.01%, 1KHz
Channel Separation: >96db (1KHz)
Analog Output: 2V
Vacuum Tubes: 12AX7 x 2, 12AU7 x 2 (output stage)
12AX7 x 1, 6N6 x 1 (high voltage stablization)
Digital Output: 0.5Vpp, 75ohms
Power Consumption: 20 watts
Dimensions: 430mm x 310mm x 115mm (LxWxH)
FEATURES:
TECHNICAL:
S/N Ratio: >102db
THD: <0.01%, 1KHz
Analog Output: 2V
Re: Jolida JD 200 tube CD player
Jd200 is the enhanced version of the very popular jd100
» Jolida JD200 tube CD Player
» JOLIDA JD200 Tube CD player
» Jolida JD1000rc MkII tube integrated amp
» Jolida JD202s Tube integrated Tube Amplifer (new)
» Jolida JD100A & FX Tube DAC (New)
