Rotel RA-931 Integrated Amplifier
Item: Rotel RA-931 Integrated Amplifier
Condition: In very good working condition. Do not have any dents or scratches.
Price: RM550
The power supply derives from a ROTEL designed and manufactured toroidal power transformer. We also utilize ROTEL custom designed capacitors to improve the speed and damping factor of the amplifier.
We believe in highly regulated power supplies and build these into all of our products. We feel the extra expense of building in an excellent power supply is worthwhile because it is good for the music.
The Bass and Treble tone controls adjust the low bass or the high treble range of the music. We do not allow them to alter the all important middle ranges (vocal range) of the music. They are deflatable with a front panel switch, if you desire to bypass them.
Links:
http://www.audioreview.com/cat/amplification/integrated-amplifiers/rotel/ra-931/prd_116118_2717crx.aspx
http://www.rotel.com/content/manuals/ra931_eng.pdf
Price: RM550
Description
The Rotel RA-931 is a stereo integrated amplifier which has been designed for high performance. It has Symmetrical Circuit Paths. These are utilized to ensure absolutely identical timing integrity between the two channels of the amplifier.The power supply derives from a ROTEL designed and manufactured toroidal power transformer. We also utilize ROTEL custom designed capacitors to improve the speed and damping factor of the amplifier.
Power output: 30 watts per channel into 8Ω (stereo)
- Frequency response: 10Hz to 100kHz
Total harmonic distortion: 0.03%
Signal to noise ratio: 95dB (line)
Dimensions: 440 x 92 x 347mm
Weight: 6.4kg
Links:
» Rotel RB 960 BX Power Amplifier and Rotel Ra04 Integrated Amp(Used)SOLD
» HIFI set for sale (Rotel Integrated Amplifier RA-971 MKII, Rotel CD Player RCD-971, B&W DM601 S2 Speaker) plus freebies - SOLD
» Rotel 931 MKII Integrated Amplifier (Used)
» Rotel RA-02 Integrated Amplifier (Used)
» ROTEL RA-931 INTEGRATED AMPLIFIER
