USA-UK 3 Prong Plug Adapter, US correct polarity, NEMA 5-15R receptable
3 posters
USA-UK 3 Prong Plug Adapter, US correct polarity, NEMA 5-15R receptable Empty USA-UK 3 Prong Plug Adapter, US correct polarity, NEMA 5-15R receptable
Post by actsessory Mon Apr 20, 2015 10:59 am
Solid built, heavy, high quality adapter (Rugged molded construction)
USA-UK 3 Prong Plug Adapter, US correct polarity, NEMA 5-15R receptable Yl3pin10
Solid copper inner, nice tight fit secured strong contact point.
USA-UK 3 Prong Plug Adapter, US correct polarity, NEMA 5-15R receptable Yl3pin11
UK BS1363 fused plug to USA NEMA 5-15R.
250V 13A
Plug your American device into the standard UK wall outlet with the correct phase polarity.
USA-UK 3 Prong Plug Adapter, US correct polarity, NEMA 5-15R receptable Yl3pin12
Convert the US plugs perfectly, the correct Live pin should be on the LEFT (with Ground pin on top) on USA plug.
USA-UK 3 Prong Plug Adapter, US correct polarity, NEMA 5-15R receptable 3_pin_10
Lifetime warranty
RM35 each.
@ 0126116917
Subang Jaya SS 14
[You must be registered and logged in to see this link.] HERE
actsessory
Number of posts : 2565
http://www.actsessory.com
USA-UK 3 Prong Plug Adapter, US correct polarity, NEMA 5-15R receptable Empty Re: USA-UK 3 Prong Plug Adapter, US correct polarity, NEMA 5-15R receptable
Post by actsessory Tue May 12, 2015 1:29 pm
Thanks for the feedback from KimSoon
USA-UK 3 Prong Plug Adapter, US correct polarity, NEMA 5-15R receptable 3prong10
actsessory
Post by andlee2k Tue May 12, 2015 5:39 pm
Why 13A higher wattage? I thought 15A should be higher wattage what?
andlee2k
Regular
Regular
Number of posts : 98
Registration date : 2011-09-29
Post by actsessory Tue May 12, 2015 6:17 pm
andlee2k wrote:Why 13A higher wattage? I thought 15A should be higher wattage what?
O.. standard 240V is 13A, and 125V is 15A.
From the statement above,
Wattage = Volt x Amp, thus 240V x 13A = 3120W (Max 3250W);
125V x 15A = 1875W
actsessory
Post by actsessory Thu May 21, 2015 5:35 pm
British Plug Adapters Series
UK ASTA approved
Approvals of :
USA-UK 3 Prong Plug Adapter, US correct polarity, NEMA 5-15R receptable Logo_c10 USA-UK 3 Prong Plug Adapter, US correct polarity, NEMA 5-15R receptable Logo_u10
CSA (Canada Standards Association)
UL (Underwritwers Laboratories)
actsessory
Post by actsessory Tue Jun 16, 2015 3:20 pm
actsessory
Post by actsessory Wed Jul 22, 2015 2:48 pm
POLARITY MATTERS!
"It was a simple matter of listening to the system with the live and neutral reversed and then switching the live and neutral wires on the Furutech power cord’s US plug connected to the wall socket to correct the polarity.
There are differences - with reversed polarity, the soundstage becomes narrower, the images are diffused, there is less transparency and the bass is softer.
With polarity corrected, the soundstage widens, the images are more ‘solid’ and have more ‘body’, transparency improves and the bass sounds stronger.
After a few songs I was convinced that polarity matters.
Reversed polarity may not affect other electrical components like fridges and kettles, but for stereo systems, it is a major degrading factor.
So, audiophiles in Malaysia (and other ex-British colonies using the BS 1363 standard) must ensure that polarity is correct when using power cords with US plugs."
actsessory
Post by actsessory Sun Aug 09, 2015 11:39 am
Ready stock now..!!  We apologies for those who came for it during KLIAV show when it was out of stock.. sorry for the inconvenience caused..
actsessory
Post by actsessory Sun Aug 23, 2015 12:09 am
Guys... item has been out of stock till next week. I apologies for the inconvenience caused..
Truly sorry for those who came for it.
actsessory
Post by actsessory Wed Sep 02, 2015 7:21 am
USA-UK 3 Prong Plug Adapter, US correct polarity, NEMA 5-15R receptable Revers10
USA plug has reversed polarity of neutral and live.
A customer used to connect US plug reserved in the above way, with the ground exposed.
After bought the adapter now for his hifi system, there seems improvement sonically.
USA-UK 3 Prong Plug Adapter, US correct polarity, NEMA 5-15R receptable 3pin_r10
and item is READY STOCK NOW
actsessory
Post by actsessory Fri Oct 09, 2015 12:02 am
Pricing remains the same still...
actsessory
Post by actsessory Mon Nov 23, 2015 11:18 pm
actsessory
Post by actsessory Thu Dec 17, 2015 12:14 am
For the US power cord, especially those factory terminated US plug power cables.
actsessory
Post by actsessory Mon Jan 11, 2016 5:01 pm
actsessory
Post by actsessory Thu Feb 18, 2016 10:05 am
Item still on sale. Price stays same.
actsessory
Post by actsessory Sun Mar 06, 2016 10:46 pm
It turns your US plug cable to correct polarity usable in Malaysia (UK Standard).
actsessory
Post by actsessory Tue Jun 28, 2016 3:12 pm
Bump for limited stock/
actsessory
Post by actsessory Wed Oct 31, 2018 5:38 pm
Back in stock... finally
actsessory
Post by actsessory Mon Nov 12, 2018 2:04 pm
Ready stock
actsessory
Post by actsessory Sat Dec 22, 2018 12:02 pm
Ready stock
actsessory
Post by actsessory Wed Jan 23, 2019 12:39 pm
actsessory
Post by actsessory Tue Feb 05, 2019 3:56 pm
Limited stock
actsessory
Post by actsessory Sun Mar 03, 2019 5:31 pm
actsessory
Post by actsessory Fri Apr 26, 2019 6:30 pm
actsessory
Post by actsessory Sat May 18, 2019 1:35 pm
Few more left
actsessory
Post by actsessory Tue Jul 09, 2019 6:07 pm
ready stock
actsessory
Post by actsessory Mon Oct 07, 2019 6:46 pm
Useful adapter that works in purpose
actsessory
Post by actsessory Sun Nov 10, 2019 8:07 pm
Ready stock
actsessory
Post by actsessory Thu Nov 28, 2019 9:14 pm
actsessory
Post by actsessory Sat Apr 11, 2020 9:51 pm
Stock back in supply
actsessory
Post by boxer Sun Apr 12, 2020 10:07 pm
Interested to get 1, postage to cheras..
boxer
Number of posts : 630
Post by actsessory Tue Jul 07, 2020 5:55 pm
Ready stock ya
actsessory
Post by actsessory Sun Aug 09, 2020 6:46 pm
New stock reached, back in supply
actsessory
Post by actsessory Mon Sep 07, 2020 6:19 pm
Ready stock
actsessory
Post by actsessory Tue Nov 10, 2020 10:06 pm
Ready stock
actsessory
Post by actsessory Sat Jan 02, 2021 8:55 pm
actsessory
