AAD C-100 Bookshelf Loud Speaker
AAD C-100 Bookshelf Loud Speaker Empty AAD C-100 Bookshelf Loud Speaker
Post by danielc100 Mon Mar 20, 2017 5:09 pm
AAD C-100 Bookshelf Loud Speaker Img_2910
AAD C-100 Bookshelf Loud Speaker Img_2911
AAD (American Acoustic Development)
design concept ----    ( Advance, Accurate, Dynamic)
Hold in your hands right cut the speakers, admire her weight - what should be a wall of MDF and magnets drivers to make such a significant effect?
Beautiful, neatly lined with persuasive speaker, with the ability to connect separate bands, it gives the impression of a much more expensive things.
Close dome tweeter corporate securely closed metal mesh.
The front panel is very tough - with a margin.
Relatively low sensitivity does not cause serious concern, especially as this loss more than offset by the smallness of the nonlinearity of products over the entire operating frequency range, frequency response stability, good value lower limit.
Thus, there are compelling reasons to rely on objective and thorough clean sound.
Column equipped with magnetic shielding that in this price range does not happen very often; and the ability to place the system close to the TV is expanding its range of home applications.
 Incidentally, the C series is extensive and includes more than a dozen different models, including the center channel speakers and subwoofers.
Sound C-100 at a comfortable volume perceived whole, complete, very tidy. His most remarkable quality - good plastic transmission melodic relief. But not "watercolor" with blurred faces uncertain transitions, and well -designed, like the images on canvas easel master of realistic painting.
In this regard, particularly want to commend clear treble. Bass for "weave" carefully planned and fully meets the ideas of his classic shelf version. Correctly transmitted tonal relations. It is necessary to note the ability of C-100 to revive images of musical instruments: special, "melodious" overtones as whimsical violin vividly reminded of the colorful richness of the original.
By lowering the volume considerably grows cold, otherwise portraits live instruments lose certainty, specific features are averaged; speakers as if unwillingly "swinging". However, these effects are typical for most small systems. Confidently behaves C-100 at high volume, the sound is just harder, upstairs there are metallic shades.
C-100 - good enough versatile option for pure stereo in smaller rooms. However, stylistic manner of yet most organic forms chamber. Two pairs get a good theatrical performance. Of course, you will need a subwoofer and center, and there is no reason to oppose a purely proprietary composition.
It would be better if you use a more powerful amplifier (at least 50 watts per channel).
Two-way reflex speakers.
Dimensions - 320x192x270 mm.
 Speakers: Bass/Woofer - head with concentric contoured 120mm cone polymer
                 HF head with 27mm dome polymer membrane. Crossover - 2 kHz.
Nominal impedance - 8 ohms. Bi-wiring/amping. magnetic shielding.
The system has a relatively low sensitivity of - 87.4 dB.
Lower frequency limit (at a level of -10 dB) - 56 Hz; serious result.
Frequency response is well balanced;
Price : RM 750
Contact Daniel 011-21838637
danielc100
Number of posts : 1
Registration date : 2017-03-19
