Technics SL-1100A w/ EPA-110 Tonearm + Technics EPC-270C MM Cartridge
![Technics SL-1100A w/ EPA-110 Tonearm + Technics EPC-270C MM Cartridge MrQWTtN](https://i.imgur.com/mrQWTtN.jpg)
"The SL-1100 turntable provides that incomparable professional Technics quality in a reasonably priced package.
The heart of this outstanding direct drive turntable is its DC brushless motor which drives the platter directly to eliminate belts, pulleys and idlers.
![Technics SL-1100A w/ EPA-110 Tonearm + Technics EPC-270C MM Cartridge EzSQKQE](https://i.imgur.com/ezSQKQE.jpg)
This simple design means fewer moving parts to wear out and greater long term reliability.
The motor of the SL1100 is controlled electronically by a DC servo which provides highly accurate rotation completely unaffected by power line frequency and voltage variations.
![Technics SL-1100A w/ EPA-110 Tonearm + Technics EPC-270C MM Cartridge 8Iu8J3X](https://i.imgur.com/8Iu8J3X.jpg)
And due to its high torque, speed remains the same even during changes of external drag.
This combination produces wow and flutter of just 0.03% WRMS and rumble of better than -70dB.
The SL-1100AC variant is identical but features an illuminated stroboscope."
![Technics SL-1100A w/ EPA-110 Tonearm + Technics EPC-270C MM Cartridge 2pDsZWV](https://i.imgur.com/2pDsZWV.jpg)
![Technics SL-1100A w/ EPA-110 Tonearm + Technics EPC-270C MM Cartridge 6vHbryH](https://i.imgur.com/6vHbryH.jpg)
Picture album here: https://imgur.com/a/D4yfL
Type: direct drive player system
Platter: 350mm, 2kg, aluminium die-cast
Speeds: 33 and 45rpm
Motor: 20 poles (rotor), 15 poles (stator) ultra low speed DC motor
Speed change method: electronic
Variable speed control: 10% range
Wow and flutter: 0.03% WRMS
Rumble: -70dB
Tonearm: EPA-110 static balance type
Effective length: 235mm
Overhang: 14mm
Stylus pressure: 0 to 5g
Dimensions: 510 x 390 x 195mm
Weight: 13.0kg
Condition: 7.5/10, only cosmetically but otherwise in good working condition! Cue-level is a little rough, but is oiled and lowers the tonearm smoothly. Both 33/45rpm speeds are rock steady and can be adjusted manually via the speed adjusters.
Price: RM 2750 w/ Technics EPC-270C Cartridge, RM 2500 w/o cartridge.
Call Greg (011-39300083, 03-76104466) for more info, or come over for an audition at APS, Lot 223 2nd Floor Amcorp Mall!
superfi- Dealer\Reseller\Trader\Service Provider
- Number of posts : 520
» Technics SL1200 TT with SME3009 tonearm
» Technics SL-1100A + Grace 707 + Ortofon MC
» Technics SP-10 MKII with Technics EPA-100 Tonearm (Used) SOLD
» Technics SL1200 Mk1 tonearm
» Technics EPC-101C mm cartridge
