Grounding a phonostage
2 posters
Grounding a phonostage Empty Grounding a phonostage
Post by kamfei0512 Tue Feb 20, 2018 9:46 am
Greeting to all,
This might sound like a noob question but I can't help but to wonder how a phonostage grounding really works.
Looking at the picture attached below, there is only a 2-pin wall wart power supply used to power this phonostage.
And the so-called "Ground" on the phonostage is mere physical contact to its casing only.
Saying this, do I need to connect additional piece of wire from phonostage to mains, in order to ground the phonostage properly (other than the ground wire from turntable to phonostage)?
Regards,
Leong
Grounding a phonostage Ln108big
kamfei0512
kamfei0512
Regular
Regular
Number of posts : 93
Registration date : 2011-02-13
Source(s): Audio Alchemy DDS II + DDE v1.1, Google Chromecast Audio
Amplification: Arcam FMJ A19
Speakers: Audio Physic Tempo 25
Grounding a phonostage Empty Re: Grounding a phonostage
Post by pleong Tue Feb 19, 2019 6:02 am
note your rca connector is also touching the case . thus grounding the case to the amp will ground all the case , the rca return .
in fact once you plug the rca to the amp , all are already grounded. but if you provide a dedicated ground wire ( thicker cable) at he ground point will be sure better.
some time , too many path of grounding will generate ground loop which will make thing bad . Hum sound.
pleong
Number of posts : 182
Registration date : 2018-01-29
