woofer recoil
4 posters
woofer recoil
Dear forumers,
I have a pair of scanspeak 6.5" woofer with burn out coil..Anyone know where can I get it recoil. Really love the sound of the woofer and quite expensive too.
Thank you.
Thank you.
Sdiahmad- New Member
- Number of posts : 4
Registration date : 2018-04-17
Re: woofer recoil
I would discourage you to rewound the voice coil as it will probably sound different from the original and the other unit. Try to find the model and always order as a pair.
vt4c- Frequent Contributor
- Number of posts : 149
Re: woofer recoil
These pair is the ori one...already replaced with new one directly ordered fr madisound... cost a bomb.
Hoping to recoil just to get it sing again. Thats all.
Re: woofer recoil
sdiahmad, i have a pair of scanspeak..had a burn out coil..went to jalan pasar, can ask around there or just go go (if im not mistaken) the store name is lamho..they'll be able to sort you out. and definitely will not cost a bomb
wsyam- Frequent Contributor
- Number of posts : 204
Registration date : 2009-07-11
Re: woofer recoil
thanks wsyam...really appreciate your info. The scanspeak woofer is a fine one, love it that is why i want to restore it.
Re: woofer recoil
Am not sure where you are located but my under hung neodymium scanspeak 6.5 in mid woofers failed 3 times and was safely repaired by CN Lim at Acoustique Systems at Amcorp Mall. Seems the units broke the wire as it entered the coil.
- Number of posts : 137
Amplification: Nuprime STA-9
Speakers: B&W 706 /AVI DM 10
