Nakamichi IA-2 Stereo Integrated Amplifier with Remote Phono MM MC
Nakamichi IA-2 Stereo Integrated Amplifier with Remote Phono MM MC Empty Nakamichi IA-2 Stereo Integrated Amplifier with Remote Phono MM MC
Post by HiFiLab Fri Dec 14, 2018 9:59 am
Nakamichi IA-2 Stereo Integrated Amplifier with Remote Phono MM MC 20181210
Nakamichi IA-2 Stereo Integrated Amplifier with Remote Phono MM MC 20181211
Nakamichi IA-2 Stereo Integrated Amplifier with Remote Phono MM MC 20181212
Nakamichi IA-2 Stereo Integrated Amplifier with Remote Phono MM MC 20181213
Nakamichi IA-2 Stereo Integrated Amplifier with Remote Phono MM MC 20181214
Made In Japan
Price : RM 1350
Vintage Nakamichi IA-2 High End Integrated Amplifier. Excellent Nakamichi quality. This is not some cheap sounding amplifier. Its not 5.1 either. Its is meant for music professionals. I played my cd's and vinyl through it.
Comes with Remote control
Power Rating: 2 x 50 watts into 8 ohms.
Amplifier circuit with harmonic time alignment (Harmonic Time Alignment) .
System precision phono equalizer.
Switch for independent tape playback and recording defeatable tone controls NF-mute. Fast response protection circuit.
Gold-Plated Phono and CD Direct Input connectors.
Dimensions: 47 x 17 x 40 cm
The IA-2 amplifier has an 18-amp peak current capability, enough to handle wide programme dynamics and effectively drive any loudspeaker load. This is achieved through the use of a massive power transformer and smoothing capacitors, with large efficient heat sinks. Power supplies are multi-regulated to keep the various stages interference-free, construction is modular, signal paths are kept very short and there is a special Nakamichi Isolated Ground arrangement.
Phono, CD, Tuner, Aux, Tape 1 and 2.
Power output: 50 watts per channel into 8Ω (stereo)
Total harmonic distortion: 0.1%
Input sensitivity: 0.125mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 70dB (MC), 82dB (MM), 105dB (line)
Output: 150mV (line)
Dimensions: 430 x 125 x 360mm
Weight: 12.5kg
HiFiLab
Number of posts : 2971
Nakamichi IA-2 Stereo Integrated Amplifier with Remote Phono MM MC Empty Bump
Post by HiFiLab Mon Jan 14, 2019 9:01 am
Up
HiFiLab
