Polk Audio T-Series T15 Stereo Bookshelf Speaker
Polk Audio T-Series T15 Stereo Bookshelf Speaker Empty Polk Audio T-Series T15 Stereo Bookshelf Speaker
Post by HiFiLab Fri Jul 19, 2019 10:01 pm
Polk Audio T-Series T15 Stereo Bookshelf Speaker 20190741
Polk Audio T-Series T15 Stereo Bookshelf Speaker 20190742
Polk Audio T-Series T15 Stereo Bookshelf Speaker 20190743
Polk Audio T-Series T15 Stereo Bookshelf Speaker 20190744
Polk Audio T-Series T15 Stereo Bookshelf Speaker 20190746
Polk Audio T-Series T15 Stereo Bookshelf Speaker 20190745
Price : RM 580
T15 Bookshelf Speakers
Speaker Use : Bookshelf
Driver Size : 1x 5 1/4" Mid/Woofer. 1x 3/4" Tweeter
Recommended Watts/Channel : 20-100 Watts/Channel
Peak Power Handling : 100 Watts
Nominal Impedance : 8 ohms
Enclosure Type : Vented
Overall Frequency : 60Hz-24kHz
Polk T Series T15 Home Theater and Music Bookshelf Speaker
The Polk T15 home theater and music bookshelf speakers are as versatile as they come, bringing incredible home theater sound and concert-quality music all in a classic look—and at a price that won’t break your budget.
We took the DNA from Polk's instant-classic Monitor Series loudspeakers and re-imagined them for today's audio lover. With one 0.75-inch silk dome tweeter, a 5.25-inch composite driver, and a performance tuned front-firing bass port—all engineered with Polk’s proprietary Dynamic Balance technology—your sonic visions of brighter highs, a wide-open mid-range and surprising bass response are now a reality. The acoustically-inert, furniture-grade MDF cabinet construction also reduces resonance and distortion, so you get rich, detailed audio the way it's meant to be heard—minus the muffled noise and rattled disruption inherent in low-quality, lesser-than audio equipment.
Designed to produce a wide dispersion sound, setting up your T15 bookshelf speakers is super straightforward and easy no matter where you place them. You can even use them as front or rear speakers in your home audio setup, too. Their five way binding posts provide an array of secure wire-hookup options. Plus, they’re designed to work with most home theater receivers, stereos or home theater processors. Whether you’re settled in for a little tube time on the couch or you’ve got the music turned up, the T15 is performance tuned to enhance the experience—that’s a fact. Premium sound paired with affordability never sounded this awesome!
HiFiLab
Number of posts : 2971
