IPUK HDD8580 USB3.0 Audiophile Videophile Linear Power SATA Harddisk Enclosure
IPUK HDD8580 USB3.0 Audiophile Videophile Linear Power SATA Harddisk Enclosure  Empty IPUK HDD8580 USB3.0 Audiophile Videophile Linear Power SATA Harddisk Enclosure
Post by actsessory Thu Aug 13, 2020 7:39 am
  • HiFi/AV-phile grade USB3.0 HDD Caddy for serious playback
  • Linear power supply
  • High quality components and parts
  • All-aluminum chassis
  • ASM controller chip solution
  • Support capacity up to 16TB
  • Specially developed by LE team for enthusiast
  • Pro version (Femto-second Clock) available.
IPUK HDD8580 USB3.0 Audiophile Videophile Linear Power SATA Harddisk Enclosure  O1cn01teqcxp1i20ufb5gr6_36070834
Audiophile + videophile grade HDD caddy is of high quailty mobile storage device specially developed for the AV/HiFi-enthusiast.
IPUK HDD8580 USB3.0 Audiophile Videophile Linear Power SATA Harddisk Enclosure  8580d
Designed and built by LE team which produced and engineered the Oppo UE (Ultimate Edition) UDP.
IPUK HDD8580 USB3.0 Audiophile Videophile Linear Power SATA Harddisk Enclosure  O1cn01t4mtln1i20vddyich_36070834
It provides a HDD enclosure function and performance, while improving data reading/writing stability, the pursuit of excellence in data retrieval quality.
IPUK HDD8580 USB3.0 Audiophile Videophile Linear Power SATA Harddisk Enclosure  O1cn01mshrem1i20udky0yh_36070834
Constant current power supply output from
+ 35W silver-copper combined toroidal transformer
+ high-speed rectifier circuit for voltage stabilization.
+ Ruby and WIMA micro filter circuitry
IPUK HDD8580 USB3.0 Audiophile Videophile Linear Power SATA Harddisk Enclosure  O1cn01aykilt1i20ugck7ms_36070834
While the harddisk racking firmly holding the drive in place, chunky isolation damping silicone feet, help reducing the HDD physical vibration during operation.
IPUK HDD8580 USB3.0 Audiophile Videophile Linear Power SATA Harddisk Enclosure  8580g
4.2kg all-aluminum chassis effectively reduces vibration from the hard drive operation.
ASM Controller chip is equipped with clock separation technology to remove jitter interference and provides stable and accurate data retrieval.
Supports HDD capacity up 16TB, tested.
The result is obviously improved color saturation, cleaner picture, quieter background and better contrast in video, and enhanced audio separation and immersion, thicker sound.
Whether you are a music or movie enthusiast, you deserve it.
**Pro, Femto Clock version**
IPUK HDD8580 USB3.0 Audiophile Videophile Linear Power SATA Harddisk Enclosure  8580-femto
Femtosecond Clock is added in PRO version, a suspension structure in used for shock absorption. Such treatment is simply “HiFi” and “feverish”.
IPUK HDD8580 USB3.0 Audiophile Videophile Linear Power SATA Harddisk Enclosure  Femto
WHAT IS FEMTO-SECOND CLOCK?
It’s a crystal (oscillator) clock of 500 times higher accuracy than the standard one out there.
Every femto-second clock used, is of military grade, each of every single clock has a serial number and individual test data report of its own.
This ensures product consistency, most stable and maximum effect.
The data conversion requires high precision, thus the higher the accuracy, lesser jitter, the more complete information, followed with much better the images and sound output.
IPUK HDD8580 USB3.0 Audiophile Videophile Linear Power SATA Harddisk Enclosure  8580e
Dimension: W330 x D230 x H70 mm
Weight : 4.6kg
Fine, transparent and solid 3D-like images with vivid color and high contrast.
Sonically full and thick yet powerful, rich in details.
A decent USB cable can further improve!  –CLICK HERE–> –>  IPUK HDD8580 USB3.0 Audiophile Videophile Linear Power SATA Harddisk Enclosure  Wireworld_starlight8usb3_square04
IPUK HDD8580 USB3.0 Audiophile Videophile Linear Power SATA Harddisk Enclosure  8581h
Price:  RM1980(Standard); RM2480(PRO)
1 Year Local Warranty
Location at Subang Jaya SS14
**Credit Card accepted.
Contact 0126116917
IPUK HDD8580 USB3.0 Audiophile Videophile Linear Power SATA Harddisk Enclosure  8580a
actsessory
Number of posts : 2479
http://www.actsessory.com
IPUK HDD8580 USB3.0 Audiophile Videophile Linear Power SATA Harddisk Enclosure  Empty Re: IPUK HDD8580 USB3.0 Audiophile Videophile Linear Power SATA Harddisk Enclosure
Post by actsessory Fri Nov 13, 2020 10:45 am
*Credit card accepted
actsessory
