Speaker Calibration Ipoh/Shah Alam & Kuala Lumpur 12/13 August 2023
Hi-Fi 4 Sale - Malaysia / Singapore Audio Forum & Marketplace | www.hifi4sale.net :: Audio & Video Equipment Marketplace :: HI-FI MARKETPLACE - NEWS, HAPPENINGS & EVENTS!
KS AV SOLUTION
***** Hurry 2 more slots to grab Sunday 130823*****
- We will be at your place *Shah Alam/KL/Selangor/Ipoh 12/13 August 2023* this weekends. Saturday and Sunday.
- Grab this opportunity and check your Lovely Home Theatre system if it really gives you what you want. 5.2.4 / 7.2.4 / 9.4.4. (Whatever Setup)
- A bad room-correction system fails to correctly determine your speaker configuration, for example, it can make voices sound boomy or thin, or create distortion that makes the system sound harsh. If the system’s designers ignored good audio science, it could end up producing a boring, dull sound—or an unnaturally glaring sound.
- A good room-correction system makes the sound more natural and pleasing. The notes in a bassline will have the same level as they do on the original recording. Explosions in movie soundtracks will slam rather than just boom. Movie dialogue will sound more realistic, not harsh, thin, or bloated. The sound may also become more enveloping.
- Furthermore, the systems sometimes lack the computing power to make an accurate assessment of the configuration of a speaker system and a room’s acoustics, and/or they lack the audio processing power to make all the needed adjustments.
- Poorly designed systems often miscalculate the bass capabilities of a speaker and the distance from the microphone to the speaker, resulting in inappropriate subwoofer crossover settings, which can make voices sound boomy or thin, and inaccurate speaker delay settings, which can ruin the sense of envelopment that a good surround-sound system produces.
Automatic calibration Problems :
- Incorrect smoothing , no windowing
- No time alignment of measurements at different locations (limitation). Timing is based on first measurement point only. Response deviates from reality by distance.
- Volume averaging of measurement rather than vector averaging completely disregarding phase cancellations: Exam, Audyssey / Dirac / YPAO = Reference / Flat and EQ Applied.
- Inaccurate delay calculation (no clock ppm correction)
- Impulse response resolution is 1/8th of that of REW for the same sampling rate and frequency range.
- Uncalibrated microphone .
KS AV SOLUTION - Professional Speakers Calibration
Full Speaker Calibration. Our calibration is based on :
- Full Flexibility on the Target Curve , Smoothing and Windowing choices , correction frequency range vs none or only available with paid apps.
- Perfect timing (cross Correlation ) and Volume level (octave range centered around the frequency) adjustment of each and every speaker in the system including ATMOS height speakers. Total 16.4 speakers.
- Correct room response measurement by accurate multiple position averaging and alignment.
- Choice of calibrated microphone and unlimited sweep length, number and resolution . (REW 200 sweeps = 8 in Multi-Q32)
- Correction of speaker/room response with optimize equalizer band adjustment .
The goal of calibrating the audio system in your home theatre is to get a smooth, even frequency response at the primary listening position. You also want the correct sounds to arrive at your ears at the correct times. In addition to the primary listening position, you should also be able to get good performance at the other seating locations - No limits.
From Our Professional Calibration We will let you know if your system in Optimize Setup. Just give 1 hour we will let you know how your system response to your room. If your are earring the correct Quality Sound or Distortion signal that you might hear it from day one and look good for you but it's not. You only earring 60% to 70% from your System. We will Tune/Calibrate 100% from your system and make your Home Theatre alive. You can immediately feel it.
Call/WhatsApp now to get an attractive Price. 0194004551.
Kalai7275- Regular
- Number of posts : 89
2 more slots available Sunday 130823 - Hurry
Kalai7275 wrote:KS AV SOLUTION
Kalai7275- Regular
» Speaker Calibration & Projector Ipoh / Shah Alam /Kajang/ SS15 Subang Jaya/ KL
» Projector & Speaker Calibration Ipoh/KL
» Speaker Calibration 16/17-09-23 Ipoh & KL
» Ipoh / KL Professional Speakers Calibration & Projector Calibration 26/27-08-23
» Alor Setar & Singapore 27&28-04-2024
