Linn LP12 - Refreshing a Legend
Linn LP12 - Refreshing a Legend Empty Linn LP12 - Refreshing a Legend
Post by mfhoh Mon Sep 18, 2023 5:32 pm
It's been awhile since I posted and some friends have asked me to share a post on setting up and rebuilding  Linn LP12s which I have done many times.
This is photo story of a strip down and rebuilding of an early 80s Linn LP12, mechanics and tonearm, recently acquired from a friend.
The rebuild actually started with the strip down and refurnishing of the "tired" plinth (which I did not take photos). The plinth is the earlier non-corner braced version with worn/aged finish but no major dent and dink or scratches. Unlike many LP12 of this era/age from our tropical/high humidity region, the integrity of the plinth is pretty decent/not compromised.
The original TT came with a white-lined bearing which I replaced with a used Cirkus bearing, clear lid and rebuilt Valhalla psu. I replaced all spares/comsumables. I initially wanted to install an Ittok LVII but ended up with the Ekos 2 just because the armrest borehole on the armboard has not been drilled.
Here are the stripped down parts.
Linn LP12 - Refreshing a Legend Linn_l39
Close-up of some of the parts.
Linn LP12 - Refreshing a Legend Linn_l41
Motor mounted
Linn LP12 - Refreshing a Legend Linn_l44
Dome shaped spacers for motor tilt adjustments.
Linn LP12 - Refreshing a Legend Linn_l43
Top plated mounting
Linn LP12 - Refreshing a Legend Linn_l46
Installing the motor tilt screws
Linn LP12 - Refreshing a Legend Linn_l42
Cirkus bearing installed on recycled subchassis
Linn LP12 - Refreshing a Legend Linn_l47
New springs, grommets and locking nuts installed
Linn LP12 - Refreshing a Legend Linn_l48
Cross brace installed
Linn LP12 - Refreshing a Legend Linn_l50
Top-plate bolted down and integrity checked
Linn LP12 - Refreshing a Legend Linn_l45
Rebuilt Valhalla PSU
Linn LP12 - Refreshing a Legend Linn_l52
Valhalla PSU mounted
Linn LP12 - Refreshing a Legend Linn_l51
Motor wiring
Linn LP12 - Refreshing a Legend Linn_l53
Incoming a/c wiring
Linn LP12 - Refreshing a Legend Linn_l54
Tonearm wire / p-clip installed and tensioned.
Linn LP12 - Refreshing a Legend Linn_l55
Vahalla switch mounted.
Linn LP12 - Refreshing a Legend Linn_l56
Wiring checked
Linn LP12 - Refreshing a Legend Linn_l58
Mounting a Linn Ekos 2.
Linn LP12 - Refreshing a Legend Linn_l57
Internal ground link installed
Linn LP12 - Refreshing a Legend Linn_l59
Armboard / Linn Ekos mounted and tonearm cable tathered
Linn LP12 - Refreshing a Legend Linn_l61
LP12 assembled, ready for spring adjustments /tuning
Linn LP12 - Refreshing a Legend Linn_l63
Springs adjustments and levelling
Linn LP12 - Refreshing a Legend Linn_l62
Armboard squared and bounce checked
Linn LP12 - Refreshing a Legend Linn_l64
Linn LP12 suspension tuned and ready for cartridge installation/listening test.
Linn LP12 - Refreshing a Legend Linn_l65
Wilson Benesch Matrix cart mounted and making music with a K&K Audio Max-Out phonostage.
Linn LP12 - Refreshing a Legend Whatsa23
A big thank you to friends who have supplied the Linn mechanics, Cirkus bearing, parts/consumables and helped rebuild the Valhalla board.
Contact me at 016-3838919 if you want your LP12 rebuilt/tuned.
mfhoh
Number of posts : 323
