B&K Components AV5125 Amplifier
5 Channel power amplifer ( 1 channel not working)
125 watts each channel @ 8 ohms
Made in USA.
In good condition 8/10.
Selling for RM1500
Contact Peter 012-3820333
SPECIFICATIONS:
Power rating: 8 ohms 125 watts @ 1 kHz / 4 ohms 185 watts @ 1 kHz
Frequency response 5 Hz - 45 kHz
Input sensitivity 1.0 Volts
THD (S+N) 0.09 % @ 1 kHz
Input impedance 33.2 k ohms
Damping factor 150
Current (peak to peak) 30 Amps
Slew rate 14 V / )sec
Dynamic headroom 1.4 dB
S/N (A-weighted) 95 dB
Voltage gain 28
Line voltage 120/220/240 VAC switchable
Dimensions (O.A.) 17"(w) X 16"(d) X 5.75"(h)
Weight : 19.5 kg
Power consumption 1220 watts max
12.2 Amps max current draw
125 watts @ no input
Replacement fuses Line -12 Amp/250 Volt Slow Blow
Rails - 4 Amp/250 Volt Slow Blow
Made in USA.
Selling for RM1500
SPECIFICATIONS:
Damping factor 150
Voltage gain 28
Weight : 19.5 kg
Last edited by peterclting on Sun Apr 14, 2024 5:53 pm; edited 1 time in total (Reason for editing : price reduced)
- Number of posts : 2533
Re: B&K Components AV5125 Amplifier
price reduced
» Bel Canto S300 Dual Mono Power Amplifier wt Level 1 Mod by Underwood Hifi & Furutech Components (Used)
» Ferrite filters for AV components (New)
» RCA Cap For Audio Components
